1964 john deere 2010 timing issues
Not sure on a 2010 but You might check the flywheel for timing marks.
The IP has the timing marks behind a cover on the side of the pump
Timing marks are on the flywheel and there is an access "peep-hole" to see in. Pump has it's marked behind the timing window (small rectangular steel plate with two screws).
