scott rollins
Hello all,
I had to send my hydro pump out to get rebuilt , the two pictures below show before and after shots. Problem is the belt pulley. I didn"t remove the pulley the shop did when they rebuilt it and when I got it back I had to install the pulley on the pump shaft, it seems pretty simple however the pulley doesn"t seem to be tight against the pump , I can grab it and pull it right off the shaft. What am I missing here ? Is there a set screw somewhere that keeps her in place?
