JD 2510 Front End Hydraulic Leak
I have a heavy hydraulic fluid leak that's coming from underneath the fuel tank area. The frame and fuel tank base prevent me from seeing the source. There are two metal lines that disappear into that area on the passenger side. What's the likely source and what must I do to get to this leak? I searched the internet for a schematic with no luck. My shop manual doesn't help either. Thanks.
If it"s an IT manual, you will be disappointed . A real operators and service manual in hard copy of CD can be obtained from the nice folks at 1-800-544-7448.
Parts manual is online at the JD web site.
If you are lucky, the leak will be a 1/4" pinched, broken, kinked , broken or pulled off weepage drain line .
If the main seal behind the dust seal has failed. She all has to come apart.
If the weenie 0.7 cu" four piston pump is in there. This is the time to upgrade to an 1.4cu" eight piston 1000 series pump.
Could be any other line, fitting or cooler leaking in there too.
