Brush Hog Blade sharpening
EDW
Hello Folks. Anyone have some advice, tips or proper methods for sharpening Brush Cutter Blades. Thanks in advance.
I remove them and use a 9 inch angle grinder on them. Just sharpen from the top side at about the same angle as a new blade. Some people sharpen then while the blades are on the machine but it is so easy to take mine (Woods) off and put them in the vise.
The hardest part is taking the blades off. I started raising the bushog with an engine hoist while still attached to the tractor and get under it with a 4 1/2" angle grinder and sharpen them on the machine. I can usually sharpen the blades in less time than it took to remove the blades.
