Big Sycamore Farm
New User
I replaced some parts on the hydraulic lift ( ram gasket (above cylinder, and o ring on piston) then re assembled. let my gaskets set and this morning drove it around. went to run it this afternoon and wouldnt go into gear just grinding. troubleshoot determined the old ( disabled) ignition switch had dropped down and locked shifter. Removed switch and reinstalled trans cover. then started then it was stuck in gear seemed like second gear then heard a pop from trans or pump housing sio shut it down. pulled shifter cover and starter rotated engine backwards and jacked up rear tires. tried to pry the shifter plates back into neutral but nothing will budge very much. tractor starts, clutch works, let off clutch (engages) and tractor dies like the trans is siezed or somthing.
any help is greatly appreciated, in a very hard financial spot with this.
thanks
Nolan
thanks
Nolan
