I"ve got a 1951 farmall m that won"t run right. It sounds like a hit and miss at low idle and sometimes with more throttle. It dies off then it revs up a bit and it keeps doing that. I rebuilt the distributor a couple months ago, just points and the condensor. about amonth later it started to sound like a hit and miss. I"m pretty sure it isn"t a fuel problem, I rebuilt the carb and cleaned it well prior to rebuilding the distributor. I"ve tried advancing the spark with the distributor but it still doesn"t sound quite right. I"ve also tried adjusting the fuel mixture and the 2 idle screws on the carb but I don't know how those screws work. I also have a new distributor cap and plug wires around if those would help the tractor. Any ideas?
