Hi. I hope I haven't missed an existing thread, searched with just "ford clutch" thru 200 posts, and can't find this one, all the great info I soaked up notwithstanding.
I've had the clutch stick for awhile now, and successfully used the inertia of the 6" mower to pop it loose at startup. Last time didn't work. Tried other things. Really stuck. Then I killed it and restarted, but there's now no power to the trans, and no PTO. Rear hydraulics work tho. No noises. Gears still look good inside when shifting around.
Thru the 2x4 inch inspection hole underneath, the release bearing looks good, slides, pushes the plate fingers (and gets spring pressure). Clutch plate housing looks good as I crank it around. Clutch disc never turns, tho. Appears to be about against the flywheel. Disc 'grab' springs look ok. It's tough to see much of the disc -what shows looks ok, haven't found any loose chunks.
I am so clueless. What's goin on?? Somethin lodged holding the plate open a smidgin? How could that be?
