1959 841D Valve Cover Gasket
Stew Mills
New User
Where will I find the correct valve cover gasket for this 1959 841D? I have seen some online and they appear rectangular without the angled corners on one side as mine has (the side opposite the fuel lines/pump). I don't need a complete gasket set as all I have done is remove the valve cover. Anyone know a part number or a link/reference to the correct gasket?
(quoted from post at 09:28:20 06/21/14) FIAT/CNH part # is D1NL6584A.
NH parts lookup
If you look closely you can see cork gasket on there and it doesn't look too terribly old (been sitting for 2-3 years) so I am curious if that's just what they did before (made their own gasket). I tried to look up the part# provided above and can't seem to locate it online.
I can get the 1/8" cork sheet locally for about $15. I guess I just trace the valve cover for the outside and then cut on the inside of that line about 3/8" or so and that'll make what I need? Seems pretty simple, just never done it before and don't want to make a rookie mistake.
