changing fan belt on mf 203 utility
leebo63
New User
I have a mf 203 utility could anyone offer a little advice on changing the fan belt or getting by the pump drive shaft or the easiest way to do it
Hi, Depending on your set up. Some had splined
shaft and will pull out with the pump, but most
had a LH thread where the shaft goes into the
c/shaft pulley hub. There is a special tool for
this(we built our own)but if no dealer you will
have to rig up something that a impact wrench can
attach to the shaft to backward wind the shaft.A
problem is they can be very "stuck". As a last
resort, at least yrs ago you can buy belts that
come in sections and they seemed to work, Chuck
(quoted from post at 09:05:54 06/25/14) Hi, Depending on your set up. Some had splined
Thanks chuck that was exactly what I needed to know
thanks for your help
