1952 ford 8n pto shaft
Anonymous-0
I have a 1952 8n and it has a pto shaft that has 32 splin. I am wanting to put a 6 spline in it with a overrun. it has an adapter with a over run but it is like a foot sticking out. can I replace the pto shaft without pulling trans apart?
Yes, you can replace PTO shaft from the rear. Either park it with front down hill, or drain the transmission/rear end. (3 plugs underneath to drain. Remove rear small plug first to help prevent a gushing oil bath)
Remove 4 bolts around rear housing and pull it out.
If you have an 8N you should put a Ford FO-4 I&T manual on your must have list. It has details for this and other procedures. Should also get an owner's manual
Shafts are available in original 1 1/8 or more universal 1 3/8 end diameter.
