Repairing cracks in tractor tires
Anyone know of a product to apply to cracking in tractor tires,have a few starting to show small cracks and would like to make em last longer or look better , thanks for any advice
I don't know of any products that will help but it helps to to keep them out of direct sunlight when not in use.
If the cracks are really small you can cover the sidewall (or the tread if you want) with petroleum jelly. The rubber will soak it up some and improve the look of the tire. I did this on my front tires when I painted the front wheels. I wiped it off 24ish hours later and it really helped the front tires. Hope this helps you.
m.e. Miller tire has a tire paint I've seen online. I've never used it, but I'm sure you can search online and find some opinions on it.
On small, non-structural cracks I have had pretty good results from urethane windshield sealer. It's already black and seems to seal and stay put pretty well. I have in on some pulling tires and you can't tell where the fix was. Mike
