Jubilee lift problem
Doug Wheeler
New User
The lift on my tractor will raise to top, stay there a few seconds and then start going down. It will not raise again until it has gone all the way down. It is terribly aggravating when I am using the post hole digger. I have changed the fluid, and it didn"t help. I"ve used some ATF and it didn"t help. What do I need to do next?
Act same whether in Position control mode or Draft control mode? Will it hold a midway position when in Position control mode? If raised & kill engine will it hold in that raised position or leak down quickly? What happens if you stop the lift a few inches short of all the way up?
If I kill the motor when the lift is at the top, it bleeds down fast until about 3/4 and then goes down very slow. If I only lift it to about 3/4 it holds ok and responds ok to the lever. The draft control lever is back, if I move it forward, the lift goes down.
(quoted from post at 14:56:56 05/28/14) If I kill the motor when the lift is at the top, it bleeds down fast until about 3/4 and then goes down very slow. If I only lift it to about 3/4 it holds ok and responds ok to the lever. The draft control lever is back, if I move it forward, the lift goes down.
t sounds like that when you go all the way to the top the piston skirt is coming out of the cylinder enough to hit a pin in the control linkage that moves the linkage & control valve from LIFT to NEUTRAL/HOLD and further to LOWER. It should only move to NEUTRAL/HOLD, but probably due to wear or mis-adjustment it is going further. If you use touch control lever to make it rise very slowly in that last 1/4, it MAY not drop at the top.
(quoted from post at 11:56:56 05/28/14) If I kill the motor when the lift is at the top, it bleeds down fast until about 3/4 and then goes down very slow. If I only lift it to about 3/4 it holds ok and responds ok to the lever. The draft control lever is back, if I move it forward, the lift goes down.
Most people say the draft control lever moves up and down, while touch control moves forward and back.
The draft control is up... if I move it down, the lift goes down... Thanks, and thanks for the advise on trying to raise it slow, I'll give that a try...
