Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Restoration & Repair Tips Board
Case 310, 1957
David Wren
05-21-2014 12:48:05
My Dad left me this old Case Tractor 310 made in 1957. Was running when parked 5 years ago. Tractor has 12 volt battery, so I assume it has converted. All wiring is shot, would appreciate 12 volt wiring diagram. Also need firing order.
Thank You
Steve@Advance
05-21-2014 14:50:40
 Re: Case 310, 1957 in reply to David Wren, 05-21-2014 12:48:05
Firing order is 1342.
The wiring is really basic. Should be able to take one wire at a time, figure out anything in doubt by process of elimination and searching basic tractor wiring and generator circuits.
It's not original, but the split plastic wiring conduit from the auto supply makes for a nice job.
Chuck MA
05-21-2014 13:23:33
Case made the 300 in both 12v and 6v depending whereit was made Racine or Rock ISLAND so it could be original
Chuck
Adirondack case guy
05-21-2014 16:37:56
 Re: Case 310, 1957 in reply to Chuck MA, 05-21-2014 13:23:33
Chuck,
All the 300's came from R I. Early ones were 6V positive ground, with 2 bolt starters. Later 300B's were changed to 12V when the newer 148 block with flange and 3 bolt starter came out. All R I tractors through 600B's were positive ground.
Loren, the Acg.
Chuck MA
05-22-2014 16:09:32
 Re: Case 310, 1957 in reply to Adirondack case guy, 05-21-2014 16:37:56
I meant 310 series pretty sure they where 12v or 6 v depending on mfg location
Adirondack case guy
05-22-2014 17:00:43
 Re: Case 310, 1957 in reply to Chuck MA, 05-22-2014 16:09:32
Chuck,
As I stated, all small framed Case tractors were built in Rock Island, up thru the 4/570s. there was never a 300 or any other small framed Case tractor built in Racine. Racine built the large frame tractors, such as DCs, LAs big 400s 500s 700s-70,- 90, and 94/96 series tractors. etc.
Loren, the Acg.
David Wren
05-22-2014 07:46:56
Interesting, I will be starting this project this weekend. I have noticed a small resistor block that looks melted. Any clue as to what that could be ?
Thank You
Steve@Advance
05-23-2014 20:54:43
 Re: Case 310, 1957 in reply to David Wren, 05-22-2014 07:46:56
The resistor is probably for the ignition coil, that is if it's in the line between the ignition switch and the coil. (I'm assuming this is gas, not diesel!)
Resistors get hot, that's just their nature. Possibly the resistor is still good, maybe just something melted on to it...
Adirondack case guy
05-21-2014 16:54:22
From our Case dealership arcives. you may have to enlarge it for clarity. Loren
David Wren
05-21-2014 13:41:06
Chuck
Made in Racine
Copyright © 1997-2015 Yesterday's Tractor Co.
