Need a little advice.I got a 1973 massey mf200 dozer with the perkins diesel.I pulled the head and there was rust on piston walls which wasnt to bad.when I drained the oil nice clear water came out first about 2 gallons and then came the oil.what im wondering is if the water came out nice and clean could there be not that much rust if any inside of engine.before I pull the oil pan which is kinda hard on this dozer should I fill it cometely up with something first to see if it might free something up.im working on pistons from the top right now.also im wondering as long as the shifter is in nuetral there shouldnt be anything keeping the engine from turning over right?.thanks
