Yesterday's Tractor Co. New Parts for Old Tractors
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Restoration & Repair Tips Board
EZGO clutch
BRIAN DAN
05-20-2014 18:17:29
68.191.144.51
I have an older 2cycle EZGO golf car that I use on the farm.
The clutch on the engine is not moving. I tried oiling the shaft so the sheaves will move in and out. Will not move. I need to remove the clutch. Does the motor have to be removed to do this or can it be done in place?
Can the clutch be rebuilt?
Thanks
Brian
[Reply]   [No Email]
GarryinNC
05-20-2014 19:01:42
66.226.47.223
 Re: EZGO clutch in reply to BRIAN DAN, 05-20-2014 18:17:29
You can make your own clutch puller, and should be able to remove the clutch without pulling the engine. The bolt that holds the clutch on is threaded into the crankshaft. Remove it. The clutch housing has a set of bigger female threads in it. They are maybe 1/2 or 5/8 fine thread. Find a bolt to fit those threads. Bolt can be 2 inches or less in length. Then get a piece of smooth rod slightly smaller than the bolt you took out of the crankshaft. Using something for a depth gage measure and cut the rod so that it bottoms out in the crankshaft and protrudes up into the big threads slightly.
Put rod into hole, thread big bolt in and you can 'push' the clutch off of the tapered crankshaft. I have used an air impact wrench or a 16" or so breaker bar. You have to figure out a way to hold the clutch and keep it from turning during this process.
I am sure you can Google EZGO clutch removal also. The ready made puller toll is about $35. I hope my reply made sense.
Garry
[Reply]  [No Email]
BriAN DAN
05-21-2014 05:21:33
68.191.144.51
 Re: EZGO clutch in reply to GarryinNC, 05-20-2014 19:01:42
Garry Thank you!
Brian
[Reply]  [No Email]
Gene Davis (Ga.)
05-23-2014 19:50:28
98.80.232.166
 Re: EZGO clutch in reply to BriAN DAN, 05-21-2014 05:21:33
When you consider the time and cost of parts rebuilding it, you could find a used one for less. We have found this out working on carts at the local golf course. New ones will set you back $150-$350, depending on the source. You will find most likely that the clutch weights and ramp buttons are hanging in grooves that are worn in the faces of the sheave in side. If this is the case you have to replace or remachine the sliding surface on the sheaves inner side. You will be wise to find a book on it. There are springs compressed under snap rings on most golf cart clutches. Sometimes when you pull them off the engine shaft you will find they are filled with dust, dirt and trash that will not let them slide in or out. Cleaning them may get you back going for a while.
On the 2 cycle E-z Go engines, it is a good idea to change the crankshaft oil seal while the clutch is off.
Try looking on various golf cart forums for parts and advice. One site that is good is this one. Buggies Gone Wild
When you reinstall a clutch on these engines, clean the inner and outer tapers off good and lightly oil both sides with some very light oil and DO NOT USE ANTISIEZE OR GREASE ON THE TAPER!
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
