Restoration & Repair Tips Board
Re: John Deere B
05-18-2014 06:01:12
check first to make sure the throttle linkages are free and not binding, a common problem is the cotter pin at carb. Could be a weak speed control spring. A governor works by using the centrifugal force of the two weights to slow the engine down, not speed it up, so if the weights are not moving properly in the governor which in turn controls the movement of throttle. Make sure your linkages are adjusted properly too, 1/2 hole short at full throttle. hope this helps
