TractorLinks.com
Restoration & Repair Tips Board
Re: John deere G governor problems
a49deere
05-18-2014 05:42:46
There are a few things that could of happened. The left hand bearing could have come apart causing the fan shaft gears to no longer mesh correctly, the inside governor lever is held on the shaft with two 1/4 inch mach. screws, one of them could have loosened up. there is also two weights that spin around shaft, held on with a small shaft and cotter pins, which could have come loose. Like others have said, there is a very strong spring on right hand side that keeps pressure on left hand sides bearing,which also keeps the cam to governor gears in mesh, suppose spring could have broke also but not likely. I"d say your looking into a governor teardown unless it's the bearing on left hand side and you haven"t torn other stuff up . hope this helps
