TractorLinks.com
Restoration & Repair Tips Board
John deere G governor problems
Jon K Smith
05-17-2014 15:45:56
I was running the ole girl through.the local parade and from the inside of the governor housing a ping occurred like a bolt or nut hitting the side of the housing, followed by a whining grinding noise. When I got home I opened the housing to Check to see if any oil came out there was none, and the plate to the housing felt as if it has pressure behind it like a spring or something was about to pop out. My question is what kind of problems will I run into and where would a good place to start be?
a49deere
05-18-2014 05:42:46
 Re: John deere G governor problems in reply to Jon K Smith, 05-17-2014 15:45:56
There are a few things that could of happened. The left hand bearing could have come apart causing the fan shaft gears to no longer mesh correctly, the inside governor lever is held on the shaft with two 1/4 inch mach. screws, one of them could have loosened up. there is also two weights that spin around shaft, held on with a small shaft and cotter pins, which could have come loose. Like others have said, there is a very strong spring on right hand side that keeps pressure on left hand sides bearing,which also keeps the cam to governor gears in mesh, suppose spring could have broke also but not likely. I"d say your looking into a governor teardown unless it's the bearing on left hand side and you haven"t torn other stuff up . hope this helps
Bob
05-17-2014 21:15:57
"My question is what kind of problems will I run into and where would a good place to start be?"
NOT sure what you've got going on, but the spring at the RH governor bearing has pushed the shaft away from the magneto (slotted drive) and if you bolt the LH cover back on the governor and the mag drive doesn't mesh up, things are gonna get UGLY!
Mike(NEOhio)
05-17-2014 19:53:25
There is a spring on the right end of the gov shaft. Oil drains back to the crankcase.
Mike(NEOhio)
05-17-2014 20:01:53
 Re: John deere G governor problems in reply to Mike(NEOhio), 05-17-2014 19:53:25
Did the governor keep working properly after the noise? Did the fan keep on turning? The gears may be shot. Could be a bearing.
