TractorLinks.com
Restoration & Repair Tips Board
Re: McCormick W6
redforlife
05-16-2014 16:36:11
what greenmech said. Since no spark your problem probly is in the mag and not on the fuel side. I would almost bet the points are corroded and need to be cleaned up is all that is wrong. Worse case, replace them and maybe the condenser for starters.
CG4440
05-16-2014 19:15:48
 Re: McCormick W6 in reply to redforlife, 05-16-2014 16:36:11
I haven"t worked on International magnetos much so this might be a stupid question, but where are the points located? Thanks.
redforlife
05-16-2014 20:53:50
 Re: McCormick W6 in reply to CG4440, 05-16-2014 19:15:48
Well, I am pretty much only familiar with the F-4 mag. I believe the mag you should have would be the H-4. On the F-4, it was really easy. You just took a cap off and they were right there. I don't think it was quit as easy on the H-4, but I wouldn't think you would have to take to much apart to get to the points if you wanta just take a stab at it. Otherwise perhaps someone else can give you some detailed info.
