I have not used the Lucas oil stop leak. I have used their heavy duty oil stabilizer in the rear ends of my 97 GMC 4X4 that were seaping around pinon on both axles. added lucas to front axle and rear axle. After about 3,000 miles they stopped seaping and thats been 7 years ago. I do use Lucas HD oil stabilizer in engines but engines were not leaking any oil. I have used it in gear boxes that were seaping and it stopped leak.
Ya. I couldn't believe how well it worked. I bought a White 2-135. When I took it to the field in the spring,oil was almost running out of the rear main in a stream. I put some in and kept running it. By the end of the first day after putting it in,it had slowed down to a drip. In three days or so it had stopped entirely.
I put it in my Farmall cub that at the rear seal oil was pouring out of it slowed it down to a small drip. I used the tractor all last summer to cut grass and replaced seal in winter when I didn"t need the tractor and had time. I was impressed with it.
