5000 ford oil pan removal
SLICK RICK
New User
Hello everybody I am the new duck in the pond & I am
wanting someone to tell me if the oil pan will come off if I roll the front assy. out or will I have to separate the the back half also.the tractor is a1968 5000 Ford.
The front end needs to be moved forward far enough to let the oil pan drop down. I use extra long bolts between the engine and front support to guide the front end then with the engine supported just roll the front end ahead. The long bolts will keep it lined up for easier reassembly. The rear of the pan will drop down from the clutch housing without any problem.
