So, just got done with a rebuild on side mount '52 8N, did the break in running. Some questions around timing, carb settings, and governor speed. I think I've read everything on the internet, understand the gist, but foggy on some stuff.
First off, idle speed was at 1200. I couldn't get it any slower. Backed the idle speed out until the screw fell out! I then went to the speed setting on governor (as max RPM was way above 2400) and tightened that down until it was all the way down. Still was way high on RPM's at full throttle.
Then proofmeter stopped working. It now has about half an hour on it, as it was brand new. Its getting power. It quit and came back then quit again. I'll check the cable next, but its still tightly secured at both ends.
I guess my question is, think the proofmeter was wrong with the RPM's to begin with?
If not, should I start messing with linkages, or replace governor?
I set timing at idle, not knowing it was 1200 RPM. Should I assume it still idles at that and reset timing to manual suggestion for that RPM level.
Could I have done something wrong with carb (did not rebuild it)? Have main mix set at 1.5 turns our, idel mix at 1 turn out (although doesn't sound like it would matter at 1200 RPM).
She seems to run well. Only odd thing is that there isn't much reaction to the throttle movement on the low end (was thinking due to idle being high). It did seem to get better when I backed out the idle screw, and idle did come down some.
The only other thing of note, not sure it matters, is I did melt the wire that goes from the coil to distrib, which then grounded out on the manifold. Was fine once I replaced that.
So, for those of you with nothing better to do this weekend, I'd love to hear your suggested troubleshooting steps!
Thanks again as always,
Matt
Matt
