2400 international brake system
JohnPaul
New User
I have a 2400 international industrial 4 cylinder diesel loader tractor and the brakes will hold up for 24 hours then need to be re-bled- Is this the master cylinder and if so where can I find parts for this tractor?
Most likely it is the master cylinder.
If the fluid is leaking out somewhere, to the point the reservoir is emptying out, you need to find the leak. Again, it could be the master cylinder, if that's where the leak is. But it could be a line or wheel cylinder.
You should be able to find the parts on this site.
