I have an 80s Ford Industrial 515 which is very
similar to the more common 4000. When I try and
raise my 3 pt it will not move until i pull the
position control almost all the way to top
position. Draft control up and draft control down
makes no difference. As it"s raising I can bump
the position lever down until it stops and it does
hold without leaking its way back down.
Any ideas on what may cause this?
Very little adjustments as I can see. I have
turned the flow control down so it is easier for
me to stop stop the system where I want it. Fast
or slow though it does the same thing.
