john deere 1010 won't start
bm77sc
New User
we have replaced points, condenser, plugs, coil. new fuel shutoff vavle, rebuilt card. manually checked timing. getting fire, and gas to carb. still not running. any ideas appreciated
How strong is the spark? Take a wire off a spark
plug, laying it against a metal part on the
crawler and stick a spark plug in the wire that
has the ground electrode removed or bent way out
of place. If you have ample spark to start a cold
engine - you will see a blue spark jumping a 1/4"
. If you have that for sure - then - after
cranking - remove a spark plug from the engine and
see if it's wet with gas. If dry - you've got fuel
problems. Any gas engine needs fuel, ample spark
at the correct time, and compression. If all else
fails - check compression. Valves often recede in
the head of 1010s and result in the rocker arms
being too tight. If no compression - check the
rocker arm adjustments.
