W4 McCormick Deering
Olie
Will someone please tell me how to remove the starter from my W4 McCormick Deering tractor. I get it almost out but there is not enough room to get it all the way out. I even broke off an ear while trying. Is there a certain way it has to come out?
I"ve been working on tractors for over 40 years but have never worked on a W4.
It's not easy. Two ways to go about it: either remove the gas tank or if you pull the bolts from the belt pulley housing you should be able to move the housing back far enough to get the starter out.
