49 Case SC Air Cleaner
FmrShane
New User
I have been trying for hours to get the air cleaner apart so i can get to the wire filter elements. Mine is filled with dirt and does not look like it has ever been cleaned. I see the little tabs at the bottom and have tried to push them in and pull the element out. No Luck am i missing something? Is there a tool that pushes all the tabs in at once? I know it can't be this hard. Thanks in advance for the help
On my 44 SC the bottom that holds up the mesh was spot welded on to the " can" or side of the unit. We cut them apart , then pulled the mesh out. When we put it together , we J B welded it in place. It seems to be ok yet. Not a fun job , but needed to be done. clint.
Take it to an automotive machine shop and have them put it in the hot tank overnight. Alot easier than taking the risk of destroying it trying to take it apart.
