Yesterday's Tractor Co.
Shop Now View Cart
Restoration & Repair Tips Board
Re: 47 8n will not throttle up
03-25-2014 00:22:40
Thanks for the reply. The carberator was just rebuilt im using a clean mason jar for fuel until my new fuel tank arrives. Im just trying to get it to run right before I put the hood and all back on. Its sucking the fuel out of the jar fine pretty quick might I add. I will take the carb. Off and just make sure everything is clean. Thanks again for your help.
03-25-2014 08:27:30
 Re: 47 8n will not throttle up in reply to 1steven, 03-25-2014 00:22:40
This tractor does not have a fuel pump as it is a gravity flow system. I don"t see how you could be getting enough fuel to run the engine. How does it get gas from the mason jar? The carb bowl must be full of gas to run properly.
03-25-2014 17:35:43
 Re: 47 8n will not throttle up in reply to Pappy, 03-25-2014 08:27:30
Quoting Removed, click Modern View to seeBecause the mason jar is upside down. lol.Agreed that's definitely part if not all the problem I'd wait on a gas tank as well.
Keith Molden
03-25-2014 13:12:47
I believe that if it were me, I wouldn't do anything to it until I got the fuel tank back and installed. Then see how it runs. As someone noted, it does not have an automatic choke like cars do. you have to keep it partially choked till the engine gets warmed up. You'll know when to push the choke in because it will start kinda pulling down and you will possibly see some black smoke comming from the exhaust. There should be a rod comming from the carburator back to below the dash. That will be your choke. Just my thoughts, Keith
