Farmall h water pump and crankshaft pully
Reedg
New User
I was wondering if the water pump sleeve presses out or if it is threaded. And does the front bolster assembly half to be removed to remove the camshaft pully. And help would be appreciated. Thanks.
(quoted from post at 17:12:29 03/23/14) I was wondering if the water pump sleeve presses out or if it is threaded. And does the front bolster assembly half to be removed to remove the camshaft pully. And help would be appreciated. Thanks.
Yes, the bolster needs to be removed to get the crankshaft pulley off.
