Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Restoration & Repair Tips Board
Re: Front bucket won't work anymore
Jack Jr
03-23-2014 17:52:52
Thank you for your reply. I took it all a part again & found the spear looking thing with the spring on it that sits between the valves wasn't in quite right. With it seated in properly I have my use of the front bucket back, but I now have my leak back as well! The tractor has the old AGIO control & the bottom plate had broken, been welded & broke again. Since it is cast iron, it isn't going to hold and finding a replacement hasn't gone so well. I haven't been able to find a foundry to make a new plate so I was just going to put on a new one, but have not been sucessfull in finding correct replacement for the plate or the two spool control. I took the control to the local hydraulic shop and they told me they don't make a replacement for either the plate or the control. I have been checking the bone yards, but still nothing. Any suggestions? Surely with all the work bulls still in use their must be a 2 spool control that is compatable.
rustyfarmall
03-24-2014 08:14:52
 Re: Front bucket won't work anymore in reply to Jack Jr, 03-23-2014 17:52:52
You can find brand new, 2 spool control valves on Amazon. Might have a slightly different mounting bolt pattern, but grab your drill and you can make it work. Way less hassle and probably cheaper than trying to fix that original.
Steve@Advance
03-23-2014 18:37:40
I would think just about any control valve assembly would work, as in replace the whole thing, valves and base plate. As long as the supply lines were the same size it should work.
Copyright © 1997-2015 Yesterday's Tractor Co.
