Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Restoration & Repair Tips Board
Re: Electric Fuel Pump for 235
Steve@Advance
03-23-2014 16:43:04
Might want to tell me to MYOB, but why put an electric pump on?
I'v seen it done, and also seen the results of leaky aftermarket pumps, a pump running when the engine is not, as in the ignition left on and the crankcase filled with fuel, fuel pumped out on a hot manifold, even worse...
Modern engines have the proper controls to prevent this. Unless you're controling the pump with this circuity, could be asking for trouble!
1959 Viking
03-23-2014 22:00:03
 Re: Electric Fuel Pump for 235 in reply to Steve@Advance, 03-23-2014 16:43:04
Steve, you have a good point. I might just consider replacing the mechanical pump to avoid any problems. Thaks for the advice.
Bob
03-23-2014 19:09:26
I agree with you that a circuit to shut it down if the engine stalls is a good idea. It's not rocket surgery to install a simple oil pressure switch circuit..
Many new generic pumps come with a wiring diagram and parts list that makes installing such a system as easy as possible..
