TractorLinks.com
Restoration & Repair Tips Board
Battery blew up / Cleanup?
Jeff From WI.
03-23-2014 14:15:08
My battery blew up in my skid steer the other day, just wondering what is the best way to clean it up. The end blew out the plastic and now you can see the insides.
I threw baking soda all over it so far.
Should I hose it down with water to?
I have chemical resistant gloves for protection and goggles along with pants.
Thanks Jeff
showcrop
03-24-2014 18:56:19
 Re: Battery blew up / Cleanup? in reply to Jeff From WI., 03-23-2014 14:15:08
Baking soda is good the key is to neutralize and dilute. Like Steve said an alkaline cleaner like CIP if you have it or oven cleaner will do a good job of neutralizing but rinse well because CIP or Oven cleaner can be more corrosive than battery acid.
notjustair
03-24-2014 17:32:22
Happened to me on a tractor one winter. I had walked about 15 feet from and it went. It sounded like a gunshot.
Steve@Advance
03-23-2014 16:57:17
Yes, it needs to be cleaned up ASAP!
Get as much water on it as you can, start with an open hose, low pressure to flush without splattering it on yourself and what might not already be contaminated.
Then switch to high pressure wash, like a pressure washer if you have one.
Remember any dirt that may have soaked up the acid will hold it and cause corrosion of anything it is in contact with. The cleaner you can get it, the better.
Follow that with an alkaline type liquid detergent or baking soda and water. A pump up sprayer will help get it into difficult areas.
Wonder why the battery exploded? Something short it out? Overcharging?
David G
03-23-2014 16:12:57
Rinse and scrub, rinse and scrub. It is very corrosive.
j hikemper
03-27-2014 13:20:57
 Re: Battery blew up / Cleanup? in reply to David G, 03-23-2014 16:12:57
after thatspry or pour old oil on it,,, leave for serveral weeks ,, pressure wash thouroughly ,, apply paint
