Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Restoration & Repair Tips Board
Re: JD 70 Head Torque amount and pattern?
Red timber
03-23-2014 10:00:47
No help for you but I am trying to get my 70 head off.....not responding to gentle persuasion,how easy did yours slide out? Might note that I am trying to leave on the manifolds as the bolts there are shot.
Thanks in advance.
TractorAddict
03-23-2014 16:51:33
 Re: JD 70 Head Torque amount and pattern? in reply to Red timber, 03-23-2014 10:00:47
I'm trying to recall if I had trouble getting it off.Had to put this project on hold and was about a year ago when I took the engine apart. The pistons were stuck from the tractor sitting so long without use. I soaked them with penetrating oil a long time before getting them freed up.
Believe the head came off relatively easy. The hard part was getting the cylinder case to budge. I might should've done like you and leave the exhaust manifold on. No matter how much penetrating oil and finesse used, still broke one bolt off. I took my time too.
redtimber
03-23-2014 18:17:48
 Re: JD 70 Head Torque amount and pattern? in reply to TractorAddict, 03-23-2014 16:51:33
thanks for the info. after some levering I have at least movement on mine so will expect it can be done. hope you have good luck finishing your project.
Copyright © 1997-2015 Yesterday's Tractor Co.
