NAA Transmission locked in second
My NAA would only move in 2nd gear or it would lock up and act like it would kill the engine. I pulled the top cover on the trans and found the detent spring on top at the end of the shift rail was in pieces.I estimated length of original based on pieces, lined up the shift to neutral and it worked. I now have the real part. Also had a problem with light switch. I found one very much like it at Autozone and half the New Holland price. I did my first plastic solder job on oil tank for a 3516 chainsaw. I used the cap from a quart of Quaker State
