TractorLinks.com
Restoration & Repair Tips Board
Re: Repairing crack in lower loader frame
bill mart
03-22-2014 16:00:06
this what wiki says too:
A flitch beam (or flitched beam) is a compound beam used in the construction of houses, decks, and other primarily wood-frame structures. Typically, the flitch beam is made up of a steel plate sandwiched between two wood beams, the three layers being held together with bolts. In that common form it is sometimes referenced as a steel flitch beam. Further alternating layers of wood and steel can be used to produce an even stronger beam. The metal plate(s) within the beam are known as flitch plates.
dpendzic
03-22-2014 18:12:46
 Re: Repairing crack in lower loader frame in reply to bill mart, 03-22-2014 16:00:06
Exactly right Bill--a flitch beam is generally a flitch plate strengthening a timber beam,
Generically a flitch plate is a metal plate added to something to increase strength.We have actually added them to steel,concrete and composite structures.
Fish plate is certainly not the correct term for this application on a steel support.
Local jargon sometimes changes the meaning of terms depending on the locale. Such as masonry and masonary
