Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Restoration & Repair Tips Board
Re: Leaking hydro oil
greygoat
03-20-2014 06:05:29
Many hydraulic pumps have a "Pinhole" drilled
from the front bearing area, to the inlet port
of the pump. Some lube gets into the bearing
area, to oil it,and/ or, when shaft gets worn, oil
that lubes the shaft gets drawn back through the
suction port, through the pinhole. When the pump
or bearings are worn out, more oil goes through than the suction port can handle, and it pops
the outer seal. Many pumps are "Non reversible".
On "Reversible" pumps, when disassembling, and
reassembling, in reverse rotation, it is vital
to note the position of the "Drain Port" !
Copyright © 1997-2015 Yesterday's Tractor Co.
