Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Restoration & Repair Tips Board
Re: Leaking hydro oil
Bob
03-19-2014 20:29:55
There is a seal (quad ring) farther inboard in the pump that does the actual sealing of pressure, then a cavity that connects to a "weep line" back to the transmission housing, then the outer seal.
Little or no oil should get past the ring, and need to drain back to the reservoir.
Once it leaks worse than what the line can handle, the pressure pops the outer seal.
At the least, the inboard seal ring has failed. Beyond that if the shaft is worn, or the bearings are worn/loose and the shaft has play it appropriate repairs will be needed.
This post was edited by Bob at 20:33:13 03/19/14.
