TractorLinks.com
Restoration & Repair Tips Board
Re: High oil pressure
JerryMT
03-19-2014 18:17:32
New bearings, properly sized, should cause an increase in oil pressure but is should stay in the green band. Relief valve could be stuck closed. Did you replace the oil pump?
ecar
03-20-2014 03:55:21
 Re: High oil pressure in reply to JerryMT, 03-19-2014 18:17:32
no- didn't replace the counter balance/oil pump assembly. I cleaned it thoroughly and it look to be in good working order. It didn't even cross my mind to take it further apart (I probably should have).
From the parts breakdown I see the relief valve is in the oil pump assembly.
I only let it run for a few minutes, I wonder if I should let it run a few more to see if the pressure drops.
JerryMT
03-22-2014 20:10:35
 Re: High oil pressure in reply to ecar, 03-20-2014 03:55:21
Generally speaking, low oil pressure is worse than high oil pressure.
