Gooniebird63
New User
Got a green 1963 2010 was running great until the deep freeze.
now that it's getting warmer out I went to Start it and it will not fire.
Gas is filling float bowl but not getting into intake.
Took carb off and cleaned all passages and ports.
Turned adjustment screw out 1 1/4 .
Almost gives your hand a hickey when you hold it over air intake.
Will run all day with sprayed starting fluid or carb cleaner.
WHAT AM I DOING WRONG !!!!! GRRRRRR
Somehow, someway, fuel is not getting through the
main jet. Take it back apart and see what could be
blocking it. All the fuel, idle, mid range, and
main, must pass from the bowl through the main jet
to get into the intake.
Does it have an adjustable main jet, or were you
talking about the idle mixture screw?
If it has an adjustable main, be sure the tip of
the adjustment screw didn't break off in the jet.
I agree with Steve.It is simply not getting fuel.If
all jets are open,are you sure there no vacume
leaks?
Did you figure out where the passage is that flows fuel from the lower area of the float bowl to the main jet area, and verify it's open?
