Waylon Westphal
New User
been restoring this tractor this winter and it was time to start it today so I got it running but it would only run at wide open on half choke. this is a rebuilt carb I purchased and a rebuilt mag I purchased. I have it rough timed and have the mag set in the middle right now not sure if I need to retard or advance. it starts right up easy but only runs at slow rpms wide open at half choke. I went through carb and float level and everything appears ok so im assuming its ignition not carb. both adjustment screws are at 1 turn but doesn"t make any difference much when I turn them while its running the idle one does but the other one doesn"t do much. any advice would be appreciated thanks
