Urgent HElp
mike kiersey
New User
Tractor experts!
I need some urgent help. I have a massey 65 tractor that has been restored some years ago and i need a replacement fuel line off part that was broken during a repair.
I am not sure of the model of the injectors hence why i need your help!
Thanks Mike
Not sure of your question as far as the model of injector. The fitting you are showing is a banjo fitting and the bolt that goes through it is a banjo bolt and there is 2 copper washers to seal it. That is the fuel return line that returns the excess fuel back to the tank. You can go to agcopartsbooks.com and login as a guest and look up the part number needed,if still available.
I will second the banjo fitting and AGCO web site. I will also suggest asking for help on the MF forum below. The guys down there can help you with navigating the AGCO site if you need it.
Hi Mike
Have you found the parts you need?
I may be able to find them.
The part you need is the leak-off line connector? Or the line itself?
Looks like in the picture...you need the parts for the no3 injector?
Also...What is your tractor serial number.
Your engine serial number should be prior to 2814847.
Get back to me with the numbers and I can do a search.
Wayne
