will-max dairy
So, this Oliver 1755 that I use. One of the issues that bugs me is exhaust at the driver's station. It seems that at some point in its life, the muffler clamp was loosened so that the muffler could be taken off quickly to park it in a low shed. This let the muffler rattle back and forth. Over time, it got sloppy; and it broke a small piece off of the end of the exhaust manifold.
So, the muffler would wobble around and exhaust would blow out of the manifold/muffler joint, fill the area under the hood and seep into the operator's (me) station.
The exhaust manifold has maybe four inches of "nipple" that the muffler mates to; then there is a lip that prevents the muffler from going any further. The break caused maybe an inch of that nipple to be lost.
I bought a new clamp and tried to re-seat the muffler. I was somewhat successful, but not what I would like. The muffler is pulled as far down as it can go. As in, the body is touching the hood. The clamp holds it in place; but the flaring of the end of the muffler and the short nipple still results in some leakage.
This is what I'm thinking...
I'll see if I can get some heavy iron pipe that matches the exhaust manifold nipple. Maybe about ten inches of it.
Set this pipe onto the exhaust manifold and use metal tape to seal the joint.
Get six inches of heavy exhaust pipe with the correct I.D. to slide over this. Take the grinder and slit it lengthwise so that it can compress.
Slide this "scab" pipe over the taped manifold to iron pipe junction and clamp above and below the joint.
This would leave me four inches of clean iron pipe that would stick out of the hood a little ways that I can now slip the muffler over and clamp the end to.
Any critiques?
Any critiques?
