will-max dairy
I'm servicing the transmission on an oliver 1755.
There is a little pin on the over-under (aka hydraul shift) linkage that moves the control spool. It's gone.
I have to install a new one. The right method is to remove the arm that holds the pin so that I can get it out in the open and pound a new pin (either an expanded dowel or roll pin) into it.
To do that, I have to remove a transmission fluid cooling line with a 3/4" flare nut fitting. The one that's there has pipewrench bite marks on it; and it's not moving. I even tried (gently) with a small pipe wrench of my own. If I just lay on the pipe wrench and ruin the flare nut to get off the line, how do I economically repair the line?
Alternative? Well...I could drill maybe a 3/8" hole in the side rail of the tractor so that I could put a 1/4" punch through the hole to pound the pin into the arm where it is.
Which alternative is best?
