1954 ford Same as Oliver? Have front loader from Oliver
rc54ford
New User
I have the opportunity to purchase a front bucket loader from an Oliver tractor. Will this work on a 1954 Ford Jubilee? Anyone have experience with this?
Thanks!!!
Jubilee is a 1953 Ford and the NAA the 1954 ford. So close to being the same model but different.
That said Oliver what???? Oliver made a good many models be it a 60 or 66 or 70 or 77 or S77 or well you get the picture. As for fitting the only Oliver that might have a loader on it that would be close would be the Oliver Super 55 but even then it would not be a direct bolt on set up
I purchased two loaders with ford row crop tractors, a 960 and a 961. Having no use for them I sold them both. One was installed on a Ford 600 and the other on an Oliver 1850. I assume that since you are asking the question that the Oliver is 55 or 550. Loaders are made to be adapted to different tractor models by means of brackets and adapters. Loader manufacturers could come nowhere near building loaders for all models. So check it out, and if you know a reasonably good fabricator he will be able to do it for you.
we have asked you what model it came off of..
if it is a 55/550 it likely can be MADE to fit with bracketry and a torch and weldor.
