transmission oil
Anonymous-0
I drained the oil out of the manual transmission on a 1936 international c-30 stake truck. the manual shows only one plug for draining AND filling and it's on the bottom edge of the case. How does onr refill the case with oil if it's on the bottom and can I ose standard hydraulic oil? Does anyone know this? Thank you
Not personally familiar with this model, but if I were doing it, and was sure there is no fill plug, I would find some way to get it in the top, like removing the shifter? Top cover? Fill it about an 1" to 1 1/2" below the bottom of the main shaft.
I suspect it originally had 90w gear oil.
