case 930 conversion
ted930
New User
I have a case 930 that uses propane and I want to convert to gas . I need all the part and advise I can get! any help would be appreciated ..thanks !!
Might want to post in the Case David Brown section. Someone might have everything you need.
Easiest way would be to find a donor tractor, get everything you would need and still have it reasonably factory.
Second best would be find a gas tractor you could look at, take pictures, make notes.
Again, this would be a question someone more familiar with Case, but some factory propane engines have higher compression ratio than gas engines. Could have preignition/detonation problems under heavy loads if this is the case.
Ask casecollectorsc on the Case board. He turned an 800LP into a gasser. Note the gas cap on top.
