12 volt 1 wire alternator
Fire520
New User
I have just recently inherited a 1952 to-30
it has a 1 wire 12 volt alt on it but in needs rewired i can't seem to find a wiring diagram for this tractor preveous owner bypassed starter switch on shifter I want to put it back the way it was from factory THANKS
Sorry but a one wire alternator is so easy to wire up a 5 year old can do it. The wire from the alternator hooks to the battery side of the solenoid so when it is running it charges. The shift starter switch is a totally different problem in it self
If you plan to go back all the way, 6 volt and generator, which if you're doing a restoration is the thing to do...
Just buy a complete wiring harness, YT's has them. It will come with a wiring diagram. These are really basic and simple, as you start threading in the harness it will be mostly self explanatory.
