scott rollins
Hi all,
Here is what I have , a used carb I found on ebay, cleaned it up put a new jet in it all seems good. It started but the spitting is worse then ever can"t ramp up the RPM"s at all now? I went with a paper gasket in the middle and a cork up top for the intake, the cork is simply material from the craft store since it never gets near the gas I thought it would work? Did I screw up doing this? To recap when I had the other carb on it would spit 50 percent of the time and well it just sounded like crap, all this time and money into the loader I want it right. But like I said now it"s spitting a lot, could it be from the cork intake gasket? Should I do a paper gasket there? I had a paper one that got destroyed and it was a lot thicker then the paper sheet I have, could I double up? The spitting has to end, I feel confident the timing is right and the flange appears to be flat not warped, why is this thing spitting so much? You would think it"s a carb issue because my old carb that was rebuilt worked but spit a little now this carb made things worse. Should I buy a new carb and start over? I also played around with the idle screw and it didn"t do anything, any help would be appreciated
