VH4D Carb Gasket
Hello all,
Here is a picture of my broken carb, I found and bought an old but new one off ebay and ready to put it in this weekend. Question is the gasket you see is thicker then the sheet type gasket I bought and traced out, should I double up, use sealant or what? Thanks Scott
Lay a straightedge across the flange, see if it's flat. If the ears are bowed up, you can remove the studs and carefully file it flat.
Once flat, a thin gasket will work. That may be why the old one broke,thick gasket and over tightening.
No sealer.
Scott
When you put carb on check for throttle linkage binding on manifold before cinching it down tight .I think the linkage would bind without the thicker gasket.Ralph
