Hi all,
Have aquired a 35x that has had some rough treatment causing a twisted front axle.The tractor has been running on the narrrowest track setting so the twist is between the centre pivot and the inner end of the movable axle. It appears to have around a 10 degree twist that is greater then normal. The workshop manual gives 5 degree caster as spec. but doesn't suggest how to bend the axle to adjust it. Do any of the MF intellegence have a proven methord of fixing? I have considerable material resoreses and I'm sure its been done before. I would be just a little more comfortable if I was following some bodies success story.
Pete
Pete
